Dear all,
We are using Email This Issue plugin in order to create Jira issue based on an incoming mail body. This works fine so far
Now we have a request in order to parse email body and then set Multiuser picker custom field with the value of the body label
The format of the body is as below sample :
Expiration Date : xxxxx
Team : Operation
Owners : User1 , User2, User3
When we parse the Owners fields as we used to do for the others, we are not able to set the Jira Customer field Owners with value of users define in the email body
Does any of you have meet this scenario and able to share the solution ?
regards
Hi Serge,
It is possible to set Multiuser picker fields from email content, but it is important to notice that you need the user's email address instead of the username. The email addresses should also be separated with a comma, like: test1@mail.com, test2@mail.com, test3@mail.com
If these conditions are met, then you can use a set field action to set the multiuser picker, by using values extracted from the email. A simple regular expression based on your example would look like this:
^Owners\s?:\s?(.*)[\n\s]?
Please note that the above regular expression is meant to serve as an example based on the available information. The actual email might contain the text string differently, so if you are still experiencing issues, I would suggest opening a request on our support portal
Best Regards,
Imre
META-INF (Email This Issue) support team
Hi @serge calderara , thanks for your post.
Have you already checked the product documentation? There is a section here which explains how to configure multi user custom fields - https://docs.meta-inf.hu/email-this-issue/email-this-issue-for-jira-server-data-center/documentation/incoming-emails/next-generation-mail-handlers#nextgenerationmailhandlers-setissuefieldssetfieldaction
If you are still having trouble, I would open a ticket to the vendor. In the past, they have been really helpful when I was trying to configure some complex requirements - https://marketplace.atlassian.com/apps/4977/email-this-issue?hosting=datacenter&tab=support
Best wishes
This is an option I think EMail tis Issue can't perform, you would need to get the users from the description via automation and then get the email address or user name via the API or advanced JSON edit in an automation, depending on the data in the description.
