How to set a custom field as mandatory based on Select List (single choice) field value ?
roniz
In the "create" screen I have a Select List (single choice) field with optional values: X and Y
and another Text Field (single line).
I want to make the Text Field mandatory but only if the value in the Select List is X.
Is it a configured JIRA option? if yes- how can I do this?
 if not- what is the simplest way to achieve this?
Tej
Required ScriptRunner plugin, add this validation at required transition
Here Single Select custom field (singleSelect) with Options X and Y where if X is selected then Text Field (textField) required
(cfValues['singleSelect']?.value == 'X' && cfValues['textField'] != null) || (cfValues['singleSelect']?.value == "Y")
Tej
roniz
thanks,
I see that the plugin is not free- Is there a free way to achieve this?
Tej
I don't think we can achieve without the plugin!
roniz
ok sad
thanks
