I need to set a font color for custom field value using script listener and below is the my code.
Field name : InternalCommunications and AllCommunication
def MutableIssue issueObject = (MutableIssue) issue
def MutableIssue parentIssue = issueObject.getParentObject() as MutableIssue
/* Set debugging level */
log.setLevel(org.apache.log4j.Level.DEBUG)
log.debug(parentIssue)
/* Initialize global objects */
def issueTypeName = issue.issueTypeObject.name
log.debug("LISTENER CPI Wiki Markup==> STARTED")
if (issueTypeName == "Payment Inquiry" || issueTypeName == "Operational Inquiry" || issueTypeName == "Policy Inquiry" ) {
/* Retrieve Comment data */
//def actualComments = ComponentAccessor.getCommentManager().getComments(issueObject)
def actualComments = ComponentAccessor.getCommentManager().getLastComment(issueObject)
log.debug("Process each comment")
actualComments.each {
//def FromEmail = it.getUpdateAuthorFullName()
def FromEmail = actualComments.getAuthorApplicationUser().getEmailAddress()
log.debug("****** getAuthorApplicationUser FromEmail "+ FromEmail)
if(FromEmail != "")
def FromEmail1 = actualComments.getUpdateAuthorFullName()
//def FromEmail = it.getAuthorApplicationUser().getEmailAddress()
log.debug("****** getAuthorApplicationUser "+actualComments.getAuthorApplicationUser())
// FromEmail = it.getAuthorApplicationUser().toString()
log.debug("****** getAuthorApplicationUser FromEmail "+ FromEmail1)
// log.debug ("FromEmail.value: " + FromEmail.value)
def InternalCommunications = customFieldManager.getCustomFieldObjects(issueObject).find {it.name == "Internal Communications"}
def AllCommunication = customFieldManager.getCustomFieldObjects(issueObject).find {it.name == "AllCommunication"}
IssueChangeHolder localFieldChangeHolder = new DefaultIssueChangeHolder()
def newStr = "\n From: " + FromEmail1 + "\n Date and Time: " + actualComments.getCreated() + "\n" +" Body: " + actualComments.getBody() +"\n-----------------------------------------------------------------------------------------------------\n"
log.debug ("newStr: " + newStr)
def newStr1 = newStr
def newStr2 = newStr
def InternalCommunicationOldValue = issueObject.getCustomFieldValue(InternalCommunications)
def ii =InternalCommunicationOldValue.toString()
def OICV = newStr1.toString()
log.debug("New Internal Comments" + OICV)
if(InternalCommunicationOldValue && !ii.contains(OICV))
newStr1 = newStr.toString()+InternalCommunicationOldValue
InternalCommunications.updateValue(null, issueObject, new ModifiedValue(issueObject.getCustomFieldValue(InternalCommunications), newStr1), localFieldChangeHolder)
log.debug("InternalCommunicationOldValue" + InternalCommunicationOldValue)
if (InternalCommunicationOldValue == null)
InternalCommunications.updateValue(null, issueObject, new ModifiedValue(issueObject.getCustomFieldValue(InternalCommunications), OICV), localFieldChangeHolder)
// InternalCommunications.setForeground(Color.white)
log.debug("COMPLETED Updating Internal Communication field")
def AllCommunicationOldValue = issueObject.getCustomFieldValue(AllCommunication)
def ac =InternalCommunicationOldValue.toString()
def OACV = newStr2.toString()
if(AllCommunicationOldValue && !ac.contains(OACV))
newStr2 = newStr.toString()+AllCommunicationOldValue
AllCommunication.updateValue(null, issueObject, new ModifiedValue(issueObject.getCustomFieldValue(AllCommunication), newStr2), localFieldChangeHolder)
log.debug("AllCommunicationOldValue" + AllCommunicationOldValue)
if(AllCommunicationOldValue== null)
AllCommunication.updateValue(null, issueObject, new ModifiedValue(issueObject.getCustomFieldValue(AllCommunication), OACV), localFieldChangeHolder)
log.debug("COMPLETED Updating AllCommunication field")
log.debug("Completed processing all comments")
event.issue.store()
log.debug("LISTENER CPI Wiki Markup==> COMPLETED for " + issueTypeName)
/* Re-set debugging level */
log.setLevel(org.apache.log4j.Level.WARN)
Read the story
