Sign up Log in
How to set a specific label when an issue is created?
Norman Hills
I'd like to set a specific label when an issue is created so that it can be caught and displayed on a project Kanban board - any ideas?
cheers
Norman
grundic
June 14, 2012
Try a post function. Here is a similar thread.
Norman Hills
Hi Grigory,
Thanks for that, looks like it would do the job. I was wondering if there is a way I can do it using javascript within the page. What I need to do is quite simple,
if issuetype=Deployment set the labels field to FRED
grundic
June 14, 2012
I successfully solved similar issue for assigne field.It is going to be more tricky for labels , because it's a multiselect field. I'll try to do my best, but without any promises :]
