How to set character limits on a custom field?
Amy Nguyen March 22, 2019 edited
I am trying to set a character limit on a custom field to be less than 750 characters. It could be from 1 character up to 750 characters including special characters like $, %,.... This is the regular expression I used but it did not work
[A-z a-z 0-9]{1,750}
What am I missing?
Thank you!
Amy
Mike Rathwell
March 22, 2019
Hi @Amy Nguyen
I'm not sure where you are setting that as it's not a "default" Jira field. I'm also assuming Jira server with this suggestion but have a look at Regex Custom Fields plugin for Jira Server. I use it for just this kind of thing in my instance.
https://marketplace.atlassian.com/apps/1211043/unique-regex-custom-field?hosting=server&tab=overview
Amy Nguyen March 27, 2019
I am setting a validator during the create transition using "Regular Expression Check (JSU).
