How to set custom field as required up on create screen
Mohamed El Taweel April 22, 2018 edited
Have workflow with three issue types. I need to set the filed "Service Type" to be required only if the issueType= "Shared Revenue"
How can I implement this request?
Example:
def rtField = getFieldByName("Service Type")
if (issue.issueTypeObject.name == 'Shared Revenue')
rtField.setRequired(true);
else
rtField.setRequired(false);
Nic Brough -Adaptavist-
April 22, 2018
You don't need a script for this.
Create two field configurations.  In one of them, make the field mandatory.  Use the field configuration scheme for the project to tell it to use the one with the mandatory flag for shared revenue, and the one where it is optional for all other issue types.
It worked properly. Thank you Nic.
Can I do it using a scriptrunner ?
April 22, 2018
A behaviour could make it mandatory, but remember that behaviours are easy to bypass.
