How to set default DueDate based on issue priority?
Thyagaraj Gopalakrishna August 5, 2019
Can anyone guide me to the right direction?. I'm looking to achieve the following.
  • Set default DueDate to 1 day while creating the ticket if Priority is Critical
  • Set default DueDate to 3 days while creating the ticket if Priority is Major
Is this possible with the stock Jira Cloud configuration without installing any additional add-ons/plugins?.
Any help is appreciated!
3 votes
Jack Brickey
You would want to look at an addon like Automation for Jira, Scriptrunner, Power Scripts, etc.
Thyagaraj Gopalakrishna August 8, 2019
Thank you. I will check it out if any of them are open source
Tarun Sapra
August 5, 2019 edited
Hello @Thyagaraj Gopalakrishna
Out of the box it's not possible, if oyu have a paid plugin like script runner then you can follow this example and implement what you want.
http://scriptrunner-docs.connect.adaptavist.com/jiracloud/post-functions.html#_calculated_custom_field
Got it. Thanks!
Looks like updating the issue's dueDate through Rest api at some scheduled interval is the option left for me.
