How to set default values for some issue fields in the create issue screen?
Javier Portillo
March 7, 2012
Hi there,
I would like to write default values in some issue fields by using a plugin when a user open the create issue screen.
Any idea to start??
Thanks a lot!
LukasG
I just came across this old question - so here is an option in 2016:
Workflow Essentials for JIRA has this kind of functionality. You can define default values on create screens for many fields, per project and issue type or globally.
Андрей Зонин October 14, 2019
180$
MinC
March 8, 2012
There is a similar feature request has been raised here: https://jira.atlassian.com/browse/JRA-4812.
Which field that you wish to be configured with default values? Probably you can refer to this page: http://confluence.atlassian.com/display/JIRA/Setting+a+Default+Value+in+the+Description+Field if you want to set a default value in the 'Description' field.
Help us plant more trees
