I am trying to clone an issue to another project and also set the Flagged custom field to "Impediment" on the cloned issue:
import com.atlassian.jira.component.ComponentAccessor def customFieldManager = ComponentAccessor.getCustomFieldManager() def cf = customFieldManager.getCustomFieldObjectByName("Flagged") def fieldConfig = cf.getRelevantConfig(issue) def optionsManager = ComponentAccessor.getOptionsManager() def value = optionsManager.getOptions(fieldConfig)?.find { it.toString() == 'Impediment' } issue.setCustomFieldValue(cf, value)
When I execute this code, I see an exception in the JIRA logs:
2016-03-29 15:42:34,210 http-bio-8080-exec-13 ERROR matt_shelton 942x5658x1 iod9tz 0:0:0:0:0:0:0:1 /secure/QuickCreateIssue.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: CAPD-31, actionId: 1, file: null com.atlassian.jira.exception.CreateException: Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: http://confluence.atlassian.com/x/3McB at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:757) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:645) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssueObject(DefaultIssueManager.java:770) at com.atlassian.jira.issue.IssueManager$createIssueObject$0.call(Unknown Source) at com.onresolve.scriptrunner.canned.jira.utils.AbstractCloneIssue.doScript(AbstractCloneIssue.groovy:96) at com.onresolve.scriptrunner.canned.jira.utils.CopyIssueWithAttachments.super$2$doScript(CopyIssueWithAttachments.groovy) at com.onresolve.scriptrunner.canned.jira.utils.CopyIssueWithAttachments.doScript(CopyIssueWithAttachments.groovy:10) at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue.super$3$doScript(CloneIssue.groovy) at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.CloneIssue.doScript(CloneIssue.groovy:85) Caused by: com.atlassian.jira.workflow.WorkflowException: Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: http://confluence.atlassian.com/x/3McB at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:923) at com.atlassian.jira.issue.managers.DefaultIssueManager.createIssue(DefaultIssueManager.java:746) ... 8 more Caused by: java.lang.ClassCastException: com.atlassian.jira.issue.customfields.option.LazyLoadedOption cannot be cast to java.util.Collection at com.atlassian.jira.issue.customfields.impl.AbstractMultiCFType.createValue(AbstractMultiCFType.java:41) at com.atlassian.jira.issue.fields.CustomFieldImpl.createValue(CustomFieldImpl.java:854) at com.atlassian.jira.workflow.function.issue.IssueCreateFunction.execute(IssueCreateFunction.java:88) at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1050) at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1446) at com.opensymphony.workflow.AbstractWorkflow.initialize(AbstractWorkflow.java:615) at com.atlassian.jira.workflow.OSWorkflowManager.createIssue(OSWorkflowManager.java:886) ... 9 more
Based on the exception, I suspect the issue here is how I'm populating value
, but I don't know how else to get it. The line in question was based on this answer, but I may be misunderstanding it.
The error is here:
This is because Flagged is (normally) a check box field and takes a Collection of Option objects.
So changing the last line to:
issue.setCustomFieldValue(cf, [value])
should work.
Attempting to get value this way also does not work, despite this being, I think, the more direct route:
def value = optionsManager.getOptions(fieldConfig).getOptionById(10000)
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
