How to set issue links through groovy in script postfunction?
miller j
 I am trying to set the issue links though post functions using groovy. I would like to create the links based on a custom field value from the current issue to the new issue.
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('<customfield_id>')
def customFieldValue = issue.getCustomFieldValue(customField)
def newIssue = 'abc-123'
if(customFieldValue  = 1){
Link blocks
else {
Link clones
Thanks a mill.
Ivan Tovbin
January 27, 2018 edited
Here's how you do it.
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def linkMgr = ComponentAccessor.getIssueLinkManager()
linkMgr.createIssueLink(11111, 22222, 33333, 1, currentUser)
/*where 11111, 22222 and 33333 are source issue id, destination issue id and issue link type id respectively */
/*currentUser is the link creator, so feel free to change it to any other Application User object*/
Qi Jiang
@Ivan Tovbin
Hi Ivan,
I did try to run this in script console instead of post function, but got some error on
 can't find match method
Ivan Tovbin
April 10, 2018
It's the usual thing with Scriptrunner's Static Type Checking not always being accurate.
In this very case you can either simply ignore this error - the code will work just fine. Or you can declare argument types like so, to make the error go away:
linkMgr.createIssueLink((Long)11111, (Long)22222, (Long)33333, (Long)1, currentUser)
Dante Labate September 10, 2018
@Ivan Tovbin
could you tell me how I remove link?
Register Now
