How to set overrideScreenSecurity=true with Python
Francesco R
October 1, 2019
I'm using jira 2.0.0 Python modules to set some customfields.
All is working but for one customfield that is not in the edit screen of the issue I'm getting the message "Field 'customfield_xxxx' cannot be set. It is not on the appropriate screen, or unknown." I've checked that I can get rid of this error setting overrideScreenSecurity tu true but I'm not able to do it using jira for Python.
I get my issues in this way:
issues = jira.search_issues(jql, start_idx, block_size)
for issue in issues:
    issue.update(fields={'customfield_10740': 'my value'})
How can I set this parameter ?
Thank you in advance.
Francesco
Mohamed Benziane
Hello @Francesco R
The error message "cannot be set. It is not on the appropriate screen, or unknown", means that the field is not on the edit screen. You will need to add it to the screen.
I think the python module work like the API REST, so you can only do what you can do on the UI.
Hope this helps
Francesco R
October 2, 2019
Yes, it's not on the edit screen and if I put the customfield on it, the python script works.
But I read that to get rid of this problem (I don't need to put the cf on the screen, it's a "service" customfield) I could set on the API rest the parameter with something like
/rest/api/2/issue/' + issueKey + '?overrideScreenSecurity=true
but I'm not able to do this with jira Python modules
Mohamed Benziane
This security parameter seems to work only for app according to the documentation
Connect app users with admin permissions (from user permissions and app scopes) can override the screen security configuration using overrideScreenSecurity and overrideEditableFlag.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/?utm_source=%2Fcloud%2Fjira%2Fplatform%2Frest%2F&utm_medium=302#api-rest-api-3-issue-issueIdOrKey-put
Like • 2 people like this
Learn more
