How to set the value of Fix Version field in an issue through groovy script?
Tony Mackin May 15, 2018 edited
We are planning to use Jira Software to track projects and tasks for a certain team.   This team wont be doing code releases so don't need to track versions.
However they want to always set the fix versions field to the same value so can use the backlog board  and version view option to see all items for their team.
How can a post-function script be used to always set the value of the fix versions field to be a default value.   For example say always want version field to be ABC.
I tried creating a post-function with the script here
https://community.atlassian.com/t5/Jira-questions/How-to-set-the-value-of-fix-version-default-field-in-an-issue/qaq-p/295929
but I get a runtime error on the line this line due to null pointer (versionn = null)
issue.setFixVersions(Arrays.asList(versionn))
Tony Mackin May 17, 2018
Thanks Alexey for your help.   This is now working.
verssionn came back as null.
I figured out problem with script thanks to your help and looking values of the fields in console messages.
In line 9 of script above it had  "WCE Security" but the actual Fix Version defined in Jira is "WCE Security Team".    Once I changed line 9 to look for the right value the script now works to automatically sets the Fix Version in all new issues created.
Alexey Matveev
May 15, 2018
It should be like this:
def version = ComponentAccessor.getVersionManager().getVersion(issue.getProjectId, "ABC");
issue.setFixVersions(Arrays.asList(version))
Tony Mackin May 16, 2018
Thanks - I modified the script with line above and getting  a run time error.
Any advise would be greatly appreciated.
In Jira project there is one version setup with value of WCE Security
Post-function script on Create transiton is:
1   // Script to set value of Version for WCE Security Project issues
2   import com.atlassian.jira.project.version.Version
3   import com.atlassian.jira.project.version.VersionManager
4   import com.atlassian.jira.issue.fields.CustomField
5   import com.atlassian.jira.component.ComponentAccessor
6   import com.atlassian.jira.project.Project
7   VersionManager versionManager = ComponentAccessor.versionManager
8
9  String valueOfversion = "WCE Security"
10 Version versionn = versionManager.getVersion(issue.getProjectId(), valueOfversion)
11 issue.setFixVersions(Arrays.asList(versionn))
12 def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
13 log.warn ("+++ Issue " + issue  + " valueOfversion = " + valueOfversion +  " versionn = " + versionn)
14 ComponentAccessor.getIssueManager().updateIssue(user, issue, com.atlassian.jira.event.type.EventDispatchOption.DO_NOT_DISPATCH, false)
And it gives this error message.... line 11 fails, with null value for versionn I believe:
2018-05-16 16:21:00,872 https-jsse-nio-9445-exec-4 ERROR (my email) 980x29159x1 ckzv38 (IP) secure/QuickCreateIssue.jspa [c.o.s.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: null, actionId: 1, file: <inline script>
java.lang.NullPointerException
 at Script1.run(Script1.groovy:11)
Alexey Matveev
May 16, 2018
Could you log the variable versionn before line 11?
log.error("versionn: " + versionn)
Alexey Matveev
May 17, 2018
@Tony Mackin It is very good to hear that it worked for you!
