How to set value of a custom field in jira using groovy script?
sandeep vb
July 12, 2015
I need to copy value of a custom field into another customfield.
I tried this.
CustomField cf1 = cfManager.getCustomFieldObject(11419)
CustomField cf2 = cfManager.getCustomFieldObject(10204)
issue.setCustomFieldValue(cf2,issue.getCustomFieldValue(cf1))
But setCustomFieldValue function makes changes only in the issue object here but changes are not reflected in database. How can I achieve this?
4 votes
Andrey Kuzmin
July 12, 2015
Hello, @sandeep vb.
Try solution that I suggested here.
sandeep vb
July 12, 2015
Thank you very much Andrey Kuzmin, I tried what you had mentioned. I could make changes in the user database successfully.
Help us plant more trees
