Hi all,
I have a problem: I want to prepare a template for an Email with the Addon "EmailthisIssue" and I want to have the summary of the linkedIssue in the text (see my example). Can you help me with the right command? I already tried with " #renderLinkedIssue($!issue.summary)" and with "#parse('templates/emailissue/email/text/issue-links.vm'). The last solution is almost what I need, but I just need the summary and it shows more than that.
"Dear $!issue.summary,
your training is on (HERE I need to put the summary of the linkedIssue)
If you have any questions, feel free to conctact me.
Best Regards"
Thank you in advance and best regards,
Maria
Hey @Mari Car
Maybe try something like this?
#if ($issue.getInwardLinks() != "[]")
#set($inwardLinks = $issue.getInwardLinks())
#set($length = $inwardLinks.legth())
<div style="display:inline; margin-right: 10px;">Links: $inwardLinks</div>
#end
Hope this helps!
