How to show attachments in Issue Navigator
Adolfo Casari
April 13, 2014
Is there any way to show in a column in Issue Navigator the names of the attachments for an issue?
Thanks in advance,
11 votes
Boris Georgiev [Appfire]
April 13, 2014
Currently not possible - https://jira.atlassian.com/browse/JRA-4737
However you might be able to implement that using custom scripted field (Script Runner) which will display attachment names for an issue and you'll be able to add it as a column in the issue navigator.
Here's a sample groovy code for the field:
import com.atlassian.jira.config.properties.APKeys
def attachments = ComponentAccessor.getAttachmentManager().getAttachments(issue)
def baseUrl = ComponentAccessor.getApplicationProperties().getString(APKeys.JIRA_BASEURL)
attachments.collect {
    '<a href="' + baseUrl + '/secure/attachment/'+ it.id +'/'+
        URLEncoder.encode(it.filename, "UTF-8") +'">' + it.filename + '</a>'
}.join("<br>")
(Modified by @Jamie Echlin [Adaptavist] to support attachment filenames containing spaces Nov 2016).
Use script field config: Template: HTML.
Adolfo Casari
April 22, 2014
Thanks for sharing the script.
Renee Lyons
Thank you, @Jamie Echlin [Adaptavist]!!
JamieA
November 18, 2016
You're welcome, and thanks to @Boris Georgiev [Botron] too wink
Oleksandr Chalyi
Thank you, that's just what we need!
Andrews September 3, 2020
I want to display sum of two number fields to third number field.
ex: 1 Support Count CRM(2.0) = 510
      2 Support Count CRM(Old) = 10
      3 Support Count CRM(New) = 4
Calculate the sum of 2 custom fields (2+3) to the third custom field (1)
  • 1= 2+3
  • 510 = 10+4
  • 524
Sunny September 3, 2020
Hello Andrews,
Create a scripted field and insert this script  below, and add the scripted field to the view screen.
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.Issue;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
def issueManager = ComponentAccessor.getIssueManager();
//your first field
CustomField custNum = customFieldManager.getCustomFieldObjectByName("numfield1");
def custNumValue = issue.getCustomFieldValue(custNum);
//your second field
CustomField anotherCustNum = customFieldManager.getCustomFieldObjectByName("numfield2");
def anotherCustNumValue = issue.getCustomFieldValue(anotherCustNum);
//your third field
CustomField anotherCustNum2 = customFieldManager.getCustomFieldObjectByName("numfield3");
def anotherCustNumValue2 = issue.getCustomFieldValue(anotherCustNum2);
if(custNumValue !=null && anotherCustNumValue != null && anotherCustNumValue2 != null) {
def finalValue = custNumValue+anotherCustNumValue+anotherCustNumValue2;
return finalValue;
Thanks!!
Like • Mechee likes this
Johan Geens September 12, 2017
This is better, it gives you clickable file names (to download them) and also lists multiple attached file names:
URLEncoder.encode(it.filename, "UTF-8") + '"' + '>' + it.filename + '</a>' + '<br>'
}.join('<br>')
Dan27
April 24, 2018 edited
Hi, @Johan Geens
I've got this error while trying this script:
2018-04-24 08:33:30,515 ERROR [customfield.GroovyCustomField]: *************************************************************************************
2018-04-24 08:33:30,515 ERROR [customfield.GroovyCustomField]: Script field failed on issue: WBL-45930, field: Attachments(Script)
groovy.lang.MissingMethodException: No signature of method: com.onresolve.scriptrunner.customfield.GroovyCustomField$_getValueFromIssue_closure1.doCall() is applicable for argument types: (java.lang.String, java.util.ArrayList) values: [Attachments, []]
Possible solutions: doCall(java.lang.Object), findAll(), findAll()
 at Script1435.run(Script1435.groovy:43)
Can you help me to figure it out?
r_k January 30, 2019
Use this groovy code in Script Field it works!! But it need to create new custom field.
Sunny January 17, 2020
I see null, Is that because of the file path?
C:\Users\home\Atlassian\Application Data\Jira\data\attachments
this my path for attachments. script seems to be good but see null when I preview.
Thanks in advance.
