How to show progress in percentage per epic in Jira Advance roadmap?
Anuj Kumar June 12, 2024
I have created a Jira advance roadmap for project where there are 12 epic and Jira only have Progress (Issue Count and Days) filter which shows details in To-Do, In-progress and Done in percentage only while we hover over each progress, but i am looking a filer which can show the overall progress in 1 or 2 digit percentage without hover over the filter.
Ivan Garcia {Appfire}
Hi @Anuj Kumar
As far as I know, that level of customization is not possible in native Jira. If you really need to visualize that data, an Atlassian marketplace app can help you achieve your goal.
I'd recommend you try for free our Dashboard Hub Pro app, which provides a Progress Tracker gadget that allows you to easily see insights on epic completion.
Hope it helps!
Danut M _StonikByte_
Hi @Anuj Kumar,
This can easily done with the Pivot Table & Pivot Chart gadget offered by our Great Gadgets app.
You just have to configure the gadget with a JQL that returns the issues from your epics: parentEpic IN (DEMO-1, DEMO-2), display the pivot table by Status Category and Epic Link fields and calculate by percentage of rows by issue count, story points or any other numerical field.
And the table will be displayed on your dashboard, showing the data in real-time.
You could start with 1-month free trial. If you have any questions, feel free to contact support@stonikbyte.com at any time.
Hope this helps.
Danut
