How to show the contents of a source file in JIRA issues?
Jeff Dickerson
Jeff Dickerson
After searching around and not finding anything, I created a JIRA issue on Atlassian's board requesting this feature.
https://jira.atlassian.com/browse/JRA-43435
Sten Sundelin
May 18, 2015
Sounds like a good way to get an answer - I have nothing else to offer. Good luck!
Jeff Dickerson
I'd like to be able to display the contents of a file from source control (specifically from Stash) directly in a JIRA issue. Bonus points for allowing the authenticated user in JIRA to directly modify the code and commit it back to source control.
The primary use case is for defining requirements using JBehave. Users want the requirements to display directly in JIRA so that developers can see them when writing code to meet the requirements, but the JBehave "code" itself should live in source control somewhere. I'd like the ability to display the contents, NOT just a link, within the JIRA interface. Ideally it would be a custom field that would allow the user to browse to the file in Stash, but if they had to manually enter (copy/paste) the file path, that would be acceptable as well.
Sten Sundelin
May 18, 2015
Hi Jeff, can you be more specific? Are you looking for a formatting rule for 'copy-and-paste' or how to connect a code repository such as svn or git to JIRA?
Register now
