I have given priories to all issues/tasks (from 1 - to 5) now I want to sort them (in an ongoing sprint) by priorities - high to low. which query should I write?
this one doesn't work => project = MyAwesomeProject ORDER BY priority DESC"
and this one also not working ORDER BY RANK
For doing so in Active Sprints, follow these steps:
I assume your priorities are done with the system field called "priority"?
This is a field that has a sort order defined by the admin, not by the content, so your order by clause will be working off that sort order, not 1, 2, 3, 4, 5 (although, as an admin, I would be setting that sort order)
Can you check that it is the system priority field that is in use, and what the sort order for your options are?
