Do you know how to start JIRA automatically after server restart? I need a script which could check if JIRA is active and if is not then start JIRA automatically. This script could function on the CRON.
Hi Pawel,
Take a look at the documentation here:
https://confluence.atlassian.com/display/JIRA/Running+JIRA+as+a+Service
Best regards,
Peter
Hi Pawel,
if you are running Jira on Windows you can configure Jira as a Service: https://confluence.atlassian.com/x/SgISCw
If it is on Linux: https://confluence.atlassian.com/x/5YeUD
Kind regards
André
Save your spot
