How to stop Custom CSS/js files from overriding JIRA Built in styles/js files
Jacob Turley May 5, 2017
Okay, to kind of explain what is going on:
I am building a plugin and am trying to create a "fancy" button(Modal) via bootstrap.  When I include the styles/scripts via:
$webResourceManager.requireResource("InfuisonSoftPlugin:customStyles")
The styles are applied, but it breaks some functionality in Jira.  The one major thing is that when I go to click the "edit" button on the view issue screen, it just sits and acts like it is loading data, but it will sit there for eternity.  Another thing is this happens:
Here is my resource code in atlassian-plugin.xml
<web-resource key="customStyles">
<resource type="download" name="bootstrap.min.css" location="bootstrap.min.css"/>
<resource type="download" name="jquery.min.js" location="jquery.min.js"/>
<resource type="download" name="bootstrap.min.js" location="bootstrap.min.js"/>
<context>jira.view.issue</context>
</web-resource>
Any ideas?
Alexander Hoset [Telenor Norway] August 8, 2017
JIRA already ships with jQuery. is there a reason you need a custom build of it?
Hi
See this for more info:
info 1
info 2
info 3
For styles atlassian uses: AUI
