How to store the checklist data, creating a checklist plugin.
Atul Patil July 9, 2018
I am working on a Jira checklist plugin, I want to store the checklist data into Jira's DB. I have created the frontend, now I am stuck how to read and write those checklist data associated with the individual project.
Yves Riel _Okapya_
Hi Atul,
If you want to create a checklist, you should create a customfield and derive from a GenericTextCFType. Then you simply create whatever internal format you want as long as it's text based. JSON would be a good one but you can use XML, YAML, etc.
Start by following this tutorial:
https://developer.atlassian.com/server/jira/platform/creating-a-custom-field-type/
Then, you'll be able to store your data by issue.
Yves
Maker of Checklist for Jira
Olga Rusnak
July 9, 2018 edited
Hi Atul, great question!
Actually, our team implemented a Jira checklist (Smart Checklist for Jira) which stores all data in Jira DB. You can check it out! It has both cloud and server versions!
Thank you for the quick response.
Actually, I tried it and its good too, but I want to learn how to create it. I am a student and want to explore in this field. Any kind of lead would help.
Pavel Pavlovsky
July 9, 2018 edited
Hey Atul,
You can use Jira Entity Properties to store the data
Check the documentation:
Pavel
Thanks, @Pavel Pavlovsky _Railsware_ it seems a good option
Atul
Yves Riel _Okapya_
July 9, 2018 edited
Moved to an answer on its own ...
