×We have a Jira project with a team of 8 developers and one Jira board "Dev-Board". We also have a group of 10+ experienced users who are willing to help by doing some user acceptance testing - they will test our application releases from the user perspective. So, we would like to include those testers into our project work in Jira in such a way that they can test specified user test cases and report bugs to the developers.
Which is "best practice" with Jira for integrating the testers in our project work without overloading the current board with too many people?
For example, I am thinking of creating a second jira board "Test-Board" within the same project containing only issues of type "Test" for the group of the testers. The bugs related to the test cases will be linked to these test cases and assigned to developers. The developers should be able to see the bugs in the "Dev-Board" solve them and assign them back for a review (jira workflow status REVIEW) to the tester.
Would this be the right solution? Is there a best practice for this use case in Jira?
Hi, do you have a screenshot of your board and the workflow of your project?
I don't think you need to add more complexity by creating a new separate board.
Hope this helps.
Thank you Joy RK,
if I could avoid complexity this would be great. I think, since the testers have their own stories of type "Test" they are independent of the development and can run the same workflow, from NEW to RESOLVED. The only exchange between testers and developers happens when a tester reports a bug - this bug then goes to a developer; the developer solves it and gives it back to the tester for a review.
Here the workflow:
Here's my thoughts (based on the available info) :)
Let me know how it goes.
