How to subtotal JQL queries
Sandra Monk
March 28, 2018
Hi, I'm managing defects with Jira.  I want to list all the defects I have yet to complete Triage on, and get a total  by priority
We have an existing board that subtotals by priority (the Kanban board) but it does not allow me to filter
I have another board that lets me filter but has no totals (Issues board), here is my filter:
project = XXXX AND issuetype = Defect AND (status = New OR Assignee = currentUser() AND status not in (resolved, released, closed))   ORDER BY priority DESC, created ASC
I have a third board that will let me enter filters, and has subtotals (by sprint)  so I know it is possible to combine the two.  I have read though the help text looking for Group By, Count or Total, and also looked for other Questions asking about this
I am not a board owner or administrator.
Please give me some tips on how to do this. How can I add a filter to the board that totals correctly, or a total to the board that filters, or change what is being filtered by on the third board?
Nguyen Tran
March 28, 2018
Hi Sandra,
I'd recommend creating a dashboard instead. You can use the "Issue Statistics" gadget. Put your filter in and set the Statistic Type to "Priority". Then you can see the total very quickly and dynamically.
Nguyen
Sandra Monk
April 2, 2018
Thanks for your help.
Piotr Bojko
April 26, 2018
Using the addon https://marketplace.atlassian.com/1218767 you would use SQL like language to have bacic queries and computations
SELECT
J.Priority,
SUM(J.Key)
FROM TABLE(JQL('Priority, Key', 'project = XXXX AND issuetype = Defect AND (status = New OR Assignee = currentUser() AND status not in (resolved, released, closed))')) AS J
GROUP BY J.Priority
With the addon you can merge the JQL queries with SQL
