How to summarize X-Ray test results in Confluence
PeterGraebner July 31, 2023
We got now X-Ray integrated in Jira and we would like to create an overview page in Confluence.
I found the same question, but unfortunately the links given in the answer from X-Ray team don't work anymore.
https://community.atlassian.com/t5/Jira-questions/XRay-Reports-Linking-an-XRay-report-with-Confluence/qaq-p/1230431
or
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/XRAY-with-confluence/qaq-p/725575
Fabio Racobaldo _Herzum_
Hi @PeterGraebner ,
you could use JIRA Issues builtin macro in order to report an overview about tests status in a confluence page
Server Datacenter : https://confluence.atlassian.com/doc/jira-issues-macro-139380.html
Cloud : https://support.atlassian.com/confluence-cloud/docs/insert-the-jira-issues-macro/
Hope this helps,
Fabio
PeterGraebner August 2, 2023
Manuel
October 31, 2024
If you're using Xray in Jira server/dc, you can use macros; no need to install anything else! See more details here along with some examples.
If you're using Xray in Jira cloud, then it's not yet possible.
