There was SAML config error on Jira and now cannot login due to SAML was selected as the primary login. Is there a way to switch SAML from the primary to the secondary authentication method in Jira Database similar like in Confluence? I used the following Rest API to delete the SAML config, but it didn't work. curl -u admin_user:admin_password -X DELETE http://base-url/*ContextPathIfAny*/rest/authconfig/1.0/saml I used Data Center version 7.8.0 and disabled all nodes except for one. Appreciate any pointers and help.
Hi @Allan Margono,
That command should work. Please share the command you're actually using.
Confirm that you are making the necessary changes to the URL that is provided.
If for example URL is jira.atlassian.com
https://jira.atlassian.com/rest/authconfig/1.0/saml
if URL is jira.atlassian.com/jira
https://jira.atlassian.com/jira/rest/authconfig/1.0/saml
Thanks, I have a wrong syntax in the cmd, forgot to remove the "ContextPath"
Using the following cmd work for me:
curl -u admin_user:admin_password -X DELETE https://base-url/rest/authconfig/1.0/saml
Register now
