How to sync between multiple JIRA server instances to 1 management instance
maya jira July 5, 2017
i want to create few JIRA server instances that will sync to one place.
do i have the option to sync all the instances to 1 place?
thanks,
Maya
Łukasz_Krupa
July 5, 2017
It is possible but you will need an addon for this. IssueSYNC can do that for JIRA Server and Cloud.
You can synchronize many instances with selected projects/issueTypes.
Regards
maya jira July 9, 2017
thanks for your reply.
do i have the option to sync 1 way?
meaning configure 1 JIRA that will be managment.
the mengment will be synced with multiple instances but the instances won't see each other?
Nic Brough -Adaptavist-
July 9, 2017
Most of the add-ons in the marketplace can be single direction, or bi-directional.
July 5, 2017
You will need a system that can "sync" between JIRA systems.  There are none built into JIRA, so you will need to write one for yourself, or better, have a look in the marketplace for add-ons to handle it.
https://marketplace.atlassian.com/search?product=jira&query=synchronize will get you a list, but you will want to narrow it down more (as it's showing things other than jira to jira)
Read the story
