How to synchronise existing JIRA projects over 2 instances
francis
Assume you have 2 teams, each using their own JIRA to manage their side of a product development project. They decide to use one of the issue sync solutions which exist on the marketplace (here)
The challenge is to setup the synchronisation such that the existing common issues are brought 'under sync': Any future changes are automatically and bidirectionally synchronised.
5 votes
francis
Exalate allows to connect existing projects by uploading a csv file  which maps local issues to the corresponding remote issue.
image2016-12-22 5:24:55.png
Check for more information Connecting existing projects
Francis
Łukasz_Krupa
December 22, 2016
Current IssueSYNC version 1.3.4 supports bulk issue creation (link to doc).
If you would like to link existing issues it is possible by inserting this into database (you will need to collect issue ids from both JIRA instances).
In case you want match issues from GUI, I suggest to request that on support (https://intenso.atlassian.net/servicedesk/customer/portal/12).
