I have a gadget that consumes a REST resource via AJAX call:
args: [
key: "version",
ajaxOptions: function ()
return {
url: "/rest/daysleftinversionresource/1.0/days-left-in-iteration/getVersion",
data: {
projectId : gadgets.util.unescapeString(this.getPref("projectId")),
==> from the other side, the REST resource method is as follow
@GET //@AnonymousAllowed //@Produces({MediaType.APPLICATION_JSON, MediaType.APPLICATION_XML}) @Path("/getVersion") public Response getVersionMethod(@QueryParam("project_id") @DefaultValue("project-10000") String key) { Long projectId = Long.valueOf(key.substring("project-".length()));
The method is always taking the default value and a warning about parameters is being consumed by a servlet is raised and a recommendation to use @FormParam instead of @QueryParam is given.
I am confused and troied so many alternatives but couldnt find a solution how to transfer my param from Gadget to REST Method,.
Do you have any recommendation ?
