How to translate options of a custom specific field
Juliane Di Lascio
We created a new field (customer specific) : Select list with simple choice.
The name of the field we translated in the needed languages, but the created option values we did not translate until yet. Where we can translate them? Is it possible to translate the option values?
3 votes
Helene Lund Engebø
A bit late, but answering nonetheless.
I don't think it's possible, unfortunately.
At least we haven't found a way to do it - and we opened https://jira.atlassian.com/browse/JRA-40049 for this particular case.
If you've found a way to do this since the question was posted, please share; if not, please vote for this issue smile
Martin Böhme
September 18, 2017 edited
But it does not work with the custom field types that Jira provides :(
Devoog admin September 18, 2017
Sorry Martin, as I told you on issue JIRASERVER-40049 we are working on this.
Sascha Ziemann
Three years later and nothing happened.
Paulo Hennig
April 23, 2015
Hello Juliane,
JIRA does not have a 100% translation. You can check it here.
You can also use this plugin that will help you with your question.
Juliane Di Lascio
I am searching if there is the possibility to translate the option-values I created by myself. I do not need any translation-tool and I don't want to translate any JIRA special text - it is a custom specific field which I have created with some option-value for selection. And I don't know if I am able to translate these options. Thanks for your answer!
