How to trigger a transition when an issue is assigned to someone
Baybars Kumbasar
I'd like to know if this scenario is possible:
My workflow is as follows:
image2016-1-26 15:52:17.png
When the ticket is on "OPEN" or " Pending (IT/L2)" statuses, I'd like the "assign" button to trigger a transition from those two (or at least one status) to "In Progress (IT/L2)" statuses. Is this possible?
Baybars
3 votes
Deleted user January 27, 2016
If you don't want to create a listener for the "issue assigned", you can just remove the native JIRA Assign button (follow the reference link below). From here, you can either:
  • Create a "Assign" transition and put the post-functions you like
  • Add the "Assignee" field to a transition that you like and put the post-functions you like
Chris Ellsworth
July 29, 2016
there is no link about how to remove the assign button
Like • Eivind Bulie Haanæs likes this
3 votes
Nic Brough -Adaptavist-
January 26, 2016
You'll need to find/write a listener that can pick up "issue assigned" and poke the issue through the transition when it's appropriate
Amir Katz (Outseer)
May 22, 2018
Hi, can anyone share such a listener?
