Hi All,
I have set up quite a few logic in terms of post functions in my workflow such that when an issue is created in my project a number of activities take place upon ticket creation.
However, if someone moves a ticket to my project from another project the same post fucntions will not trigger on the new ticket. I am wondering if there is a way to trigger an Issue Create event when a ticket is moved from another projet to my project.
Thank you
It's not a "create" though. The issue already exists, it's got content and a history.
What you need to do is trap the "move" event and replicate the post-functions in a listener.
With a listener - they're for picking up and responding to events.
I have a similar problem. I have scripts on postfunctions that are triggered on a create event, and I need them to trigger on a move issue event. Postfunctions are Scriptrunner scripts on the server. Is there a way to reuse them? Because I have a problem with Available binding variables. Binding variable issue is available in workflow postfunction, and event isn't. And it is vice versa for script listeners.
Does anyone have any suggestion how to overcome this?
Marina
You'll need to copy your post-function scripts over into listener scripts that catch the "move issue" events.
Thanks for the quick response!
So, you are saying, I'll need to manage duplicate code? I would like to reuse code. Is there a way to make the script aware of the context? Is there a way to do that without writing a plugin?
Cheers!
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
