How to understand Log's referral number: 4ae4b7f8-3fad-4e4d-a535-c1e54c0872b5
shital chande August 30, 2019
Technical details
Cause
Referer URL: http://localhost:8082/plugins/servlet/upm?source=side_nav_manage_addons
java.lang.NoClassDefFoundError: jcifs/smb/NtlmPasswordAuthentication
and I am using Jira 7.13.0 so anyone helps me?
Gonchik Tsymzhitov
August 30, 2019
Hi!
Looks like classloader issue.
Let's restart your instance.
BTW, what did you do on managed apps directory plugins/servlet/upm ?
Have you updated some apps ?
shital chande August 31, 2019
Hi Gonchik,
Thanks for replying to me. Yes, I am developing Archiving Attachment plugin. and I am facing some errors and I have looking for log file also but this error I cant understand.
Error :
at com.vps.jira.plugin.servlet.Archiveing.doGet(Archiveing.java:83) [?:?]
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:635) [servlet-api.jar:?]
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) [servlet-api.jar:?]
 at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:37) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:45) [atlassian-plugins-servlet-4.5.1.jar:?]
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) [catalina.jar:8.5.32]
 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) [catalina.jar:8.5.32]
 at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.5.32]
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) [catalina.jar:8.5.32]
 at com.atlassian.jira.web.filters.JiraLastFilter.lambda$doFilter$0(JiraLastFilter.java:39) [classes/:?]
 at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1471) [tomcat-coyote.jar:8.5.32]
 at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) [tomcat-coyote.jar:8.5.32]
 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_181]
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_181]
 at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.5.32]
 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
and Log file error is :
2019-08-31 13:31:54,209 http-nio-8082-exec-20 ERROR [o.a.c.c.C.[.[localhost].[/].[default]] Servlet.service() for servlet [default] in context with path [] threw exception
java.io.FileNotFoundException: D:\Atlassian\Home\Jira_7.13\logos\jira-favicon-scaled.ico (The system cannot find the file specified)
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at com.atlassian.jira.lookandfeel.filter.ImageDownloader.doDownload(ImageDownloader.java:57)
at com.atlassian.jira.lookandfeel.filter.FaviconInterceptor.doFilter(FaviconInterceptor.java:85)
... 8 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.lang.Thread.run(Thread.java:748).
Can you help me for resolving errors?
Gonchik Tsymzhitov
August 31, 2019
Well, could you provide a pom.xml with jcifs groupid?
Thank you Gonchik,
Yes, i will provide you jcifs groupid.
<dependency>
<groupId>org.samba.jcifs</groupId>
<artifactId>jcifs</artifactId>
<version>1.3.3</version>
</dependency>
and POM.xml
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.vps.jira.plugin</groupId>
<artifactId>Archiveing-Attachment</artifactId>
<packaging>atlassian-plugin</packaging>
<name>Archiveing-Attachment</name>
<version>1.0.0-SNAPSHOT</version>
<description>This is the com.vps.jira.plugin:Archiveing-Attachment plugin for Atlassian JIRA.</description>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<build>
<plugins>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-plugin</artifactId>
<version>${testkit.version}</version>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>com.vps.jira.plugin.api,</Export-Package>
<!-- Add package import here -->
<!-- <Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", *</Import-Package> -->
<Import-Package>
</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>maven-refapp-plugin</artifactId>
<configuration>
<pluginArtifacts>
<pluginArtifact>
<groupId>com.atlassian.activeobjects</groupId>
<artifactId>activeobjects-plugin</artifactId>
<version>${ao.version}</version>
</pluginArtifact>
<pluginArtifact>
<artifactId>activeobjects-refapp-spi</artifactId>
</pluginArtifact>
</pluginArtifacts>
<productVersion>${refapp.version}</productVersion>
</configuration>
</plugin>
<plugin>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
<pluginManagement>
<plugins>
<!--This plugin's configuration is used to store Eclipse m2e settings only. It has no influence on the Maven build itself.-->
<plugin>
<groupId>org.eclipse.m2e</groupId>
<artifactId>lifecycle-mapping</artifactId>
<version>1.0.0</version>
<configuration>
<lifecycleMappingMetadata>
<pluginExecutions>
<pluginExecution>
<pluginExecutionFilter>
<groupId>
</groupId>
<artifactId>
</artifactId>
<versionRange>
[1.2.13,)
</versionRange>
<goals>
<goal>
</goal>
</goals>
</pluginExecutionFilter>
<action>
<ignore></ignore>
</action>
</pluginExecution>
</pluginExecutions>
</lifecycleMappingMetadata>
</configuration>
</plugin>
</plugins>
</pluginManagement>
</build>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<dependency>
<version>0.20</version>
</dependency>
<dependency>
<groupId>org.json</groupId>
<artifactId>json</artifactId>
<version>20090211</version>
</dependency>
<dependency>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<artifactId>jira-testkit-client</artifactId>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>servlet-api</artifactId>
<version>2.4</version>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.6.6</version>
</dependency>
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>httpclient</artifactId>
<version>4.1.1</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.templaterenderer</groupId>
<artifactId>atlassian-template-renderer-api</artifactId>
<version>1.3.1</version>
</dependency>
</dependencies>
<properties>
<jira.version>7.3.1</jira.version>
<amps.version>6.2.6</amps.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
</project>
POM.xml  ->
<organization>
</organization>
<build>
<plugins>
<plugin>
<configuration>
<pluginArtifacts>
<pluginArtifact>
</pluginArtifact>
</pluginArtifacts>
<instructions>
<Import-Package>
</Import-Package>
</instructions>
</configuration>
</plugin>
<plugin>
<configuration>
<pluginArtifacts>
<pluginArtifact>
</pluginArtifact>
<pluginArtifact>
</pluginArtifact>
</pluginArtifacts>
</configuration>
</plugin>
<plugin>
<executions>
<execution>
<goals>
</goals>
</execution>
</executions>
<configuration>
<dependency>
</dependency>
</configuration>
</plugin>
</plugins>
<pluginManagement>
<plugins>
<plugin>
<configuration>
<pluginExecutions>
<pluginExecution>
<groupId>
</groupId>
<artifactId>
</artifactId>
<versionRange>
[1.2.13,)
</versionRange>
<goals>
<goal>
</goal>
</goals>
<action>
<ignore></ignore>
</action>
</pluginExecution>
</pluginExecutions>
</configuration>
</plugin>
</plugins>
</pluginManagement>
</build>
<dependencies>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
<scope>test</scope>
</dependency>
<dependency>
</dependency>
</dependencies>
<properties>
</properties>
</project>
