How to uninstall JIRA Service Desk
George Lewe (LSY)
October 29, 2015
Hi all,
we had installed JIRA Service Desk but decided not to use it. We uninstalled the plugin but are still stuck with custom fields, link types and such, obviously related to it. We are searching for a detailed documentation about what we can safely remove/delete after uninstalling it.
Is there such a documentation?
Best regards,
George
3 votes
Joel Brown January 26, 2017
Navigate to: admin/billing/applications
click "deactivate" next to service desk
Jamie Gerace
Worked for me, thanks!
Like Gyver Chang likes this
Jonas Sieber
January 4, 2017
We would also like to remove the Service Desk Trial Version from our JIRA Cloud, and I find it MOST annoying that this is not possible! Is there still no possibility to remove this add-on completely from our account?
Sarah A
March 14, 2019
Hi everyone,
If you are getting a message that Jira cannot be upgraded because it wants you to upgrade Service Desk first, or that you have to put in a valid license for SD before you can login, but your trial of Service Desk (aka SD) has been uninstalled without uninstalling the license key first, then here's what you need to do (no $ needed!):
1. Download the SD installer.
2. Reinstall SD.
3. Go to my.atlassian.com.
4. Click New Evaluation License (we let you have up to 3 for the same server).
5. Go to your Jira landing page.
     If you get the one that says you can't start Jira until you give Service Desk a license, put in your new license.
     If you can still get into Jira then go into the Settings -> Applications page and put in the new license.
Now you can log in and/or upgrade.
NOW what you should do is go to the Applications page, DELETE the trial license for SD, then uninstall SD again.  This will keep it from barking about SD licensing in the future because there will be no license in the database anymore.
For reference: https://confluence.atlassian.com/jirakb/startup-check-jira-licensing-issues-888257801.html
Cheers!
Sarah Amann
Jira Support Engineer
Sarah A
March 14, 2019
Also, I do realize that this does not address how to purge Service Desk leftovers in the database, it was just meant to be helpful for those who are being prevented from upgrading Jira or logging into Jira post-upgrade.
Ryan Skousen
April 22, 2019
How can we purge Service Desk Leftovers from the DB?
Antti Seppänen
May 15, 2019
This is something I'd like to know, too. We once had a 3 user starter license for Jira Service Desk but since then Jira has been upgraded multiple times and at some point Service Desk was uninstalled. Now we are planning to take Service Desk into use with a much more agents but the leftovers of the old installation are blocking us from using Service Desk. To be specific, newest version will just complain that we must first upgrade to SD < 3.2 before upgrading to newest. And of course, SD 3.1.9 requires an old version of Jira. I really don't want to downgrade our Jira just to upgrade old, unnecessary demo data.
Anastasia Robey
August 18, 2020
Add me onto the list of people who want to know how to remove these custom fields.  Doesn't seem to be an actual answer anywhere.
Anonymous September 16, 2020
Hi, we have a similar problem: Currently we are working with the stack Jira, Jira Servicedesk, Confluence and Insight. Unfortunately, an error occurred during the installation of the service desk. Normally we work with the English language software modules. But the service desk was installed in German. Therefore there are e.g. various statuses in the system in both English and German. This messes up the complete process logic and confuses the employees. Is there any experience and best practices on how best to correct such an error?
Phuc Phan Hong October 22, 2018
This is really bad, the jira service desk charged me 200$ and I could not found a way to uninstall it, I was mistake to click install before and did not use anything!
Dennis_H
The above seemed to work  for me. My bill estimate changed and SD is no longer listed
Under admin, manage subscriptions, I could press delete. I got warnings that everything related to SD will be deleted, so this should work...
Dave Bosman
January 18, 2017
Go to JIRA administration ==> applications
Click uninstall under JIRA Service desk
image2017-1-19 8:49:40.png
David Downey
October 12, 2017
has anyone been successful in fully removing JIRA Service desk using the uninstall mentioned above?
Pål Frogner Hansen
March 12, 2018 edited
Like Andrea Urban likes this
Rodrigo Rosa
October 29, 2015
Hello George,
This is our documentation about how to uninstall JIRA Service Desk: https://confluence.atlassian.com/display/JIRAKB/How+to+remove+or+disable+a+Service+Desk
George Lewe (LSY)
November 12, 2015
This article is unfortunately not sufficient. Just disabling the plugin and deleting the project is not enough to remove all traces of SD from JIRA. We have even uninstalled the plugin and deleted the project, but still there are link types, custom fields and more objects like that still floating around. Can you please provide a list of all configuration objects that the SD plugin creates when it is installed. That would help identifying and removing them manually.
Ross McKenrick
May 2, 2016
@Rodrigo Sogari [Atlassian]: I agree with @George Lewe. Your answer does not address the question. We also installed JIRA Service Desk and have decided not to use it. The post that you reference only explains how to disable service desk for a specific project or to delete a service desk project. How do we uninstall Service Desk entirely–including all the related custom fields, issues, issue type schemes, security roles, etc?
Deleted user May 24, 2016
I share the notion and looking for a way to uninstall SD altogether but there seems to be no means for doing that
Jon Sword
June 20, 2016
Hi @Rodrigo Sogari [Atlassian],
I agree with the above comments. I am trying to move a project from one instance to another and the project import is blocking me from importing because my project "requires" the Service Desk custom fields.  Service Desk has been removed from the instance for months!
BruceK July 2, 2016
I also agree with the above comments.  There should be a method for uninstalling Service Desk.  I tried to remove Service Desk about a year ago and did not succeed.  For other reasons we now need to remove Service Desk and there still seems to be no way to accomplish this.
Zoran Birač
July 15, 2016
This Service Desk seems to be blocking our upgrade to JIRA 7.0
It will say the licence is too old and gives some options to remove it. But that seems to break the upgrade and leaves me with an unfixable error (and a broken system)
There was a problem adding Upgrade Task Drops the entityproperty_identity index in entity_property table to the Upgrade History. This means the state of the system may be out of sync with the upgrade history, which could result in missed downgrade tasks for future exports.
I cannot find any traces to remove it. But it needs to be gone.
Like Alex Schuster likes this
Steven F Behnke
July 29, 2016
If you're still seeing this issue you should open a Support issue, they can help you with database inconsistencies.
Zhiyan Xu
September 20, 2016
I'm researching the topic of "if we decide not to use service desk, is there a way to uninstall it completely or we need to rebuilt our DEV environment (our sandbox and initial configuration place)". Please, George, Ross, Joh, Zoran, Ran, Bruce, eventually did you go the route of rebuilt your DEV environment including server setup?
Dennis Klieverik
October 18, 2016
URGENT !! We had a look at service desk 3 or so years ago, decided not to use it and now after many upgrades I'm stuck with it in JIRA 7.2.
Please tell me how to remove the plugin altogether.
(stuff can stay in the database aslong as it doesnt break things.)
Anders Lantz December 21, 2016
Still nothing?
