Sign up Log in
How to update a parent field when subtsk state changes
Ratna Kumar Lekkala September 14, 2017
I want the parent field "Code completed on" to current date when the sub-task "Coding" is moved to done state. What is the best approach?
Marcos PS [DEISER]
Two ways...
1. You can do it using JIRA Suite Utilities "Update Any Issue Field (JSU)" post-function called from subtask transition:
2. Using ScriptRunner, you can check this post since this was already answered there... yes, I know, its old but it can give you a clue ^^
Greetings!,
Marcos.
