How to update assign field per project
Az December 8, 2017
I wanted to find out how to update the dropdown list of assignees per project.
Thomas Schlegel
Hi Aaz,
you control that with the permission scheme of your project.
Look here:
http://<your-jira-url>/plugins/servlet/project-config/<projectkey>/permissions
In that scheme, you have a permission called "Assignable User" - this is the one, you have to change.
Az December 8, 2017
yes, I got it 2 seconds after I posted the question :P
I wasn't able to delete the question...
Thomas Schlegel
Hi @Az,
please restore your question. Other users may have the same problem and search for a solution here.
It would be nice, if you would also check the question answered, so answered question can be found much better.
Thank you
Thomas
Az December 8, 2017
@Thomas Schlegel I can do that, but in general, is there no way to delete a question once asked?
Nic Brough -Adaptavist-
December 8, 2017
Champions can move them to a "removed" area which hides them.
Generally, we prefer questions to remain, so they can help people with similar problems.
