How to update custom field description?
Tsol
April 11, 2012
Hi everybody,
I have some custom fields and i've tried to edit the description. I've changed the description but the new description is not rendered in the issues related screens.
Any ideas how to do it?
Kostas
23 votes
Renjith Pillai
April 11, 2012
Update your field configuration scheme of your project and put in the description there.
AKASH BHARDWAJ
Thanks it has helped!!
Philippe-Antoine_Laurence
August 31, 2015
Good call!
Jennifer Zou
Works like a dream!
Patrick October 12, 2017
Hi all I got the same problem, but text doesn´t change according to defined text - any ideas?
Chrisjir Parkin
This solved my problem even though I don't have a Field Configuration Scheme for this specific project in which this field is used.  I was able to update the field description under "Field Configurations" by clicking on "Default Field Configuration" and looking for (CTRL-F) the particular field names whose descriptions I needed to change.
Like • 5 people like this
Gregory Hicks
@Chrisjir Parkinty, I have been racking my brain trying to figure this out and your post saved the day!
Like • 2 people like this
Jensen Jian
August 28, 2019
Nice,this is very useful.
Patrick Heidel
Instead of changing the description within the field configuration scheme, you should be able to delete the description there. After that the translated Description will be refreshed.
Like • Casey Gould likes this
3 votes
Ibrahim
November 10, 2014
I've made a feature request to see if we can make this more intuitive within JIRA.
JRA-40782
The full documentation on custom field description behavior is found here: Configuring a Custom Field.
Adding a snippet of the documentation here as well.
Changing the description of a custom field
Not changing the description in a field configuration means that any changes you make to a custom field's description are not seen.
JIRA allows you to define a description of a custom field, and if the field configuration descriptions are left empty then the original description text will appear when you create or edit an issue, and as help text in the Issue Navigator. However you can also define different description texts in each field configuration and this will override the original field description text.
For example if a custom field "My Field" is defined with a description of "This is my field" and no field configuration changes are made, then the displayed text will be "This is my field" as expected. If field configurations are used and a description "This is my excellent field" is set for the custom field in the field description, then the displayed text will be "This is my excellent field".
Faisal Shamim May 25, 2020
I can't see the description under field on Issue view screen, I can see it on Edit
AKASH BHARDWAJ
 @Ibrahim Labras : Thanks for the info, I ran into the same issue.
Akash
