How to update fields via script (listeners)?
NewByatl
June 14, 2021 edited
Hello, im trying to update filed to null value with listeners. Aftet update logs shows me nothing, no errors, but nothing is changed, field still not empty. What wrong with my script?
short description of script: if value 1 == error or customization; then value 2 = null, then value 3 = null and ect
type fields:
value 1 - (type: Deviniti [Dynamic Forms] - Dynamic Select)
value 2 3 and others ( types: Deviniti [Dynamic Forms] - Dynamic Select, multiple select list, text field)
Script:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.CustomFieldManager
def issueManager = ComponentAccessor.issueManager
def issue = event.issue
def field_1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Тип запроса")
def field_2 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Пояснение к ЭФ")
def newValue = issue.getCustomFieldValue(field_1)
if (newValue =="Ошибка"){
field_2.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(field_2), null), new DefaultIssueChangeHolder())
}else if (newValue =="Настройка"){
PD Sheehan
June 15, 2021
My suspicion is that you can't update Devinity Dynamic Form fields like that. This is okay for most regular custom fields.
With Dynamic form, what you actually want to use their own API: https://deviniti.com/support/addon/server/dynamic-forms/latest/bundled-fields-java-api/
I have no experience with that. I just found the reference page.
NewByatl
All right, thnk u! I'll rebuild script and back soon.
PS: few days ago devinity custom field was hidden by regular script. I think something wrong with current script, cause i cant change even regular textfields :(
NewByatl
I made it. Just needed to use next if (newValue.toString() =="Ошибка")
