How to update linked issues custom field upon workflow status update?
Sandesh TM
We are having issue types-say 'A' and 'B', 'B' type issues are linked to a 'A' issue type.
We need to update 'B' issue type custom field to the workflow status of 'A' issue type upon the 'A' issue type workflow status transitions.
Is there any way to achieve this feature?
Marc - Devoteam
January 23, 2025
Hi @Sandesh TM
Yes use automation rules for this.
Based on transition of Issue type A update the custom field on Issue type B
Sandesh TM
@Marc - Devoteam
Thank you for the response.
We don't have Automation rules plugin, is there any other solution for this?
Marc - Devoteam
January 23, 2025
Hi @Sandesh TM
You should have since version 9 in DC automation is included.
Or are you running a lower version?
You will require automation for this, or scripting app like scriptrunner.
Sandesh TM
@Marc - Devoteam
Yes we are running a lower version i.e 8.5.17.
Marc - Devoteam
January 23, 2025
Hi @Sandesh TM
I suggest that you update to a later version.
You are now 2 major version behind.
Later LTS version for DC after 8.5 are 9.4/9.12/10.3
https://confluence.atlassian.com/jirasoftware/jira-software-release-notes-776821069.html
Kishan Sharma
Hi @Sandesh TM
In Jira Data Center, you can use Automation feature to create a rule, which can update a custom field in IssueType B when IssueType A is transitioned to different status. You can try something like below -
In the below example, if any Story is transitioned to another status, its linked issue's Description is updated to the status of Story.
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
