Is there a way to update ticket links via Jira Importers Plugin?
It seems there is no description about how to do it at https://confluence.atlassian.com/adminjiraserver078/importing-data-from-csv-947189128.html.
Hello Li Huang,
I hope you are having a nice day.
Yes, you can update existing issues of JIRA using CSV import. You only need to map the existing issue-key column when importing the issue.
In fact, the easiest way to update issues using CSV would be by:
- Exporting your issues to CSV - So you have a template of your issue fields:
Issue-key, Summary, Status, Assignee
ABC-123, test summary, open, Petter
- Performing the changes you want in the CSV file, but keeping the same issue-key
- Import the CSV back to your JIRA Instance with the new updates:
ABC-123, changed summary, In progress, Petter
Let me know if this information helps.
Thanks Petterson. If links are already imported, how can the links be removed and updated with new links via CSV import? I tried the approach you mentioned above, but it did not help.
