Hi All,
I am trying to use Misc Custom field plugin,
I am using the 'Calculated Number Field'. I would like to sum to list fields values (with the option 1,2,3)
and than to have a condition for the value I receive.
I have tried with a basic configuration - bet even that not working for me
<!-- @@Formula:
value = issue.get("customfield_11104" + issue.get("customfield_11108"
return value -->
Can you please advise what am I doing wrong?
Naama
Hei Naama,
in your first attempt you ommitted several ) and semicolons at the end. Please try this:
<!-- @@Formula:
if (issue.get("customfield_11104")==null) return null;
if (issue.get("customfield_11108")==null) return null;
value = issue.get("customfield_11104") + issue.get("customfield_11108");
return value;
I did not use an or conjuction as you probably may want to test to different values (and not only null) as well.
Greetings
Maud
Hi Maud,
Thanks for your replay,
I manage to figure it out in the end ![]()
Can you please let me know if for Text calculated field I can add an icon?
Naama
Hello All,
Even if I put a very simple sentence such as
<!-- @@Formula:
return issue.get("customfield_11104").intValue(); -->
I do not get any value.
Can you please advise what am I doing Wrong?
Naama
