How to use Post Function "Set Field Value to constant or Groovy expression" & add Current User
Wayne Cranford September 19, 2017
I am trying to add the current user of the workflow action to a custom Single User Picker field using the "Set Field Value to constant or Groovy expression" post function.
We are using Script Runner version 2.1.17 with JIRA version 6.2.4, build # 6261, Our IT support is busy preparing to upgrade our JIRA instance to version 7.x, for over 1700 active users, so will not be able to assist for the next several weeks.
I tried using the snippet:
com.atlassian.jira.component.ComponentAccessor.getJiraAuthenticationContext().getUser()
as documented in https://innovalog.atlassian.net/wiki/spaces/KB/pages/138353228/Getting+the+current+user+from+Groovy
but when I have the Value Type - Groovy Expression I receive:
"Sorry, we had some technical problems during your last operation"
with the cause:
java.lang.NoClassDefFoundError: Could not initialize class org.codehaus.groovy.runtime.InvokerHelper
So I assume there is more to the groovy expressions I need to include in the Value box.
I am not new to JIRA as I am responsible for over 35 workflows and have used many examples I have found online over the years to incorporate requested workflow operation, but I am stuck on this one. Unfortunately I am NOT a software developer and have no experience with creating scripts.
Steven F Behnke
September 19, 2017
You're conflating two plugins.
  • ScriptRunner by Adaptavist
  • Misc Custom Fields by Innovalog
Can you locate the same error in the Error Logs? It might have more relevant information.
Thank you, I have requested the Error Log from my IT Support. Not sure if this provides any greater details, but this is the complete output that is returned in the "Sorry" message:
 at groovy.lang.GroovyObjectSupport.<init>(GroovyObjectSupport.java:32)
 at groovy.lang.Binding.<init>(Binding.java:33)
 at com.innovalog.jmwe.plugins.functions.SetFieldValueFunction.executeFunction(SetFieldValueFunction.java:67)
 at com.innovalog.jmwe.plugins.functions.AbstractPreserveChangesPostFunction.execute(AbstractPreserveChangesPostFunction.java:121)
 at com.opensymphony.workflow.AbstractWorkflow.executeFunction(AbstractWorkflow.java:1050)
 at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1446)
 at com.opensymphony.workflow.AbstractWorkflow.doAction(AbstractWorkflow.java:564)
 at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowActionInsideTxn(OSWorkflowManager.java:957)
 at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowAction(OSWorkflowManager.java:912)
 at com.atlassian.jira.bc.issue.DefaultIssueService.transition(DefaultIssueService.java:450)
 at com.atlassian.jira.web.action.issue.CommentAssignIssue.doExecute(CommentAssignIssue.java:192)
 at webwork.action.ActionSupport.execute(ActionSupport.java:165)
 at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:87)
 at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
 at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
 at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
 at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
 at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225)
 at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154)
 at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
 at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
 at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87)
 at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22)
 at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
 at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
 at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:39)
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
 at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38)
 at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
 at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
 at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
 at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92)
 at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
 at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
 at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
 at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
 at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
 at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
 at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
 at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181)
 at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85)
 at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124)
 at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
 at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:234)
 at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
 at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:169)
 at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
 at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:61)
 at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
 at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
 at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
 at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
 at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
 at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
 at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
 at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
 at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
 at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55)
 at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
 at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
 at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
 at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:78)
 at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41)
 at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:57)
 at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
 at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
 at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
 at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
 at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
 at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
 at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
 at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
 at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
 at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
 at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
 at java.lang.Thread.run(Unknown Source)
