How to use SQL to get plugins license status?
New February 12, 2018
Hi Support,
We want to write a groovy scripts or use rest api to get all the trial plugins license status
and before the license expire date the system will send mail to administrators automatically.
Thank you!
Alexey Matveev
February 12, 2018
Hi Support,
Is it possible to use groovy scripts to do it?
Thank you!
New February 13, 2018
Please respond. This is urgent
Thank you!
Nic Brough -Adaptavist-
February 16, 2018
Yes, you could dig through the API for pluginlicencemanger type stuff, but in this case, unusually, I'd step away from ScriptRunner, and do it over REST, as Alexey mentions.
At a glance, it looks like you'll need SR code to get admin, iterate over the add-ons, check the licence, work out dates, and dump the results out into something you can read.
Or, you could use a single line of code to make a REST API call to get some standardised JSON, and then a few lines of script to parse it and send emails if needed.
New February 28, 2018
Hi Support,
I use the following code:
For example:
1. http://localhost:8080/rest/plugins/1.0/  to get all jira plugin's key
2.Search for the key name: com.onresolve.jira.groovy.groovyrunner
3.Convert to expire date information
http://localhost:8080/rest/plugins/1.0/com.onresolve.jira.groovy.groovyrunner-key/license
"maintenanceExpiryDateString": "30/March/18"
My question is: we have around 10 trail plugins,how could I  batch get all plugin's expire date information,thank you in advance!
New March 1, 2018
The question is urgent,please respond as soon as possible,thank you!
New March 1, 2018
March 3, 2018
We're not support, we're a community of end-users who try to help each other.
(and even if we were "support", what you're doing is not something support would cover - the APIs are available, it's up to you how you use them)
Also, I apologise for the slow response.  Something has gone wrong with the Community's email and I've only just been notified of your question.
The way to "batch" your queries depends on what you're using to make them.  Your code or script should issue a call to get the list, then iterate over the response, using whatever iteration methods it supports.
New March 5, 2018
It seems that it did't respond the questions.
Mayar Sahab Mohamed December 28, 2018
Please have you found any solution for this ?
Like • Ramy Osama likes this
December 28, 2018
We haven't, because there was no response to the point that "The way to "batch" your queries depends on what you're using to make them.  Your code or script should issue a call to get the list, then iterate over the response, using whatever iteration methods it supports."
Like • Nikita likes this
what i actually need is to send an email to certain jira admins with the trial license status of sme plugins .
Please support and thank you for your help .Thank you
