How to use a Radio Button to validate a transition
Karl Samson
I'm trying to setup a 'Simple Scripted Validator' using ScriptRunner. That allows the transition, if the Radio button in question has 'No' selected.
"import com.atlassian.jira.component.ComponentAccessor
// Get the custom field manager
def CustomFieldManager = ComponentAccessor.getCustomFieldManager()
// Get the custom field by name
def approvalField = customFieldManager.getCustomFieldObjectsByName("Verification?")
// Get the value of the custom field for the current issue
def approvalValue = issue.getCustomFieldValue(approvalField as String)
// Check if the custom field value is not "Yes"
return approvalValue != "Yes"
    return true"
The Script Editor likes the code, but the transition is blocked, whether 'Yes' or 'No' is selected!?
Can anybody show me where my code is wrong please?
Thanks.
Jim Knepley - ReleaseTEAM
I think that getCustomFieldObjectsByName returns a collection of CustomField objects and you're looking at that collection as though it's a discreet "yes/no" value.
Try something simpler:
def approvalValue = issue.getCustomFieldValue("Verification?")
SERVER
VERSION
9.12.8
