How to use a duration field in Issue Search
SMAtlassianMber
October 2, 2018 edited
I created a new ScriptRunner Script Custom field for "Days in Current Status" using the Duration Template, but when I try to use this field in my Issue Search nothing works. What is the correct format for a duration field?
Ex. Displays on Jira Issue - 1 year, 18 weeks, 6 days, 18 hours, 12 minutes
I would like to search for issues over 5 days
"Days in Current Status" ~ '>=5days'
Pavel Abdi December 16, 2019
Hi everyone,
I can't get the Duration search work correctly. I set up a Script Field to calculate time in progress as described here https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html#_total_time_this_issue_has_been_in_progress
The displayed value seems to be correct. However, when I try to search by the script field it shows incorrect results. For example, the search "Time in progress" > 2d" also showed an issue with the value "1 day, 1 hour, 56 minutes".
What am I doing wrong?
SMAtlassianMber
There is an outstanding Bug regarding scriptrunner and duration fields.  - https://productsupport.adaptavist.com/browse/SRJIRA-3215
@SMAtlassianMber Thank you for pointing this out to me.
JP _AC Bielefeld Leader_
October 3, 2018
Hi Shelli,
maybe a bit far off, but we use something like:
status changed after "-5d"
without the use of a custom field.
Best
JP
SMAtlassianMber
Thank you JP. That is very helpful, but I would still like to figure out how to use the actual field.
Learn more
