How to use the Groovy Script Runner to create user.
Takashi Hattori June 9, 2016
Hello team
I would like to use groovy script runner to "create user" and "add User to Group". Please tell me how to write groovy script "create users" and "add user to group".
Do you have any sample groovy script? Thanks.
Boris Georgiev [Appfire]
June 9, 2016
Code for creating a user
ComponentAccessor.getUserUtil().createUserNoNotification(username, "",
emailAddress, displayName, null);
And for adding user to group you can use com.atlassian.jira.user.util.UserUtil.addUserToGroup(Group, User)
Georgiev-san Thank you very much for your information.
Code for creating a user -> I succeeded.
>import com.atlassian.jira.component.ComponentAccessor
>def userUtil = ComponentAccessor.getUserUtil()
>userUtil.createUserNoNotification("TEST MAN1111","","TESTMAN@TEST.com","TEST MAN1")
I try to use UserUtil.addUserToGroup of JIRA api but adding user to group failed.
>userUtil.addUserToGroup("gr_Admin","TEST MAN1111")
errormessage:
>No signature of method: com.atlassian.jira.user.util.UserUtilImpl.addUserToGroup() is
>applicable for argument types: (java.lang.String, java.lang.String)
>values: [gr_Admin, TEST MAN1111] Possible
>solutions: addUserToGroup(com.atlassian.crowd.embedded.api.Group, com.atlassian.crowd.embedded.api.User),
>addUserToGroups(java.util.Collection, com.atlassian.crowd.embedded.api.User)
I am sorry to cause you inconvenience, but I am looking forward to your reply.
Best Regards,
Takashi
June 9, 2016
Hi Hattori-san,
here's the full code for adding user to group
import com.atlassian.jira.component.ComponentAccessor;
def uu = ComponentAccessor.getUserUtil()
def user = uu.getUserByName("boris.georgiev")
def group = uu.getGroupObject("jira-developers")
uu.addUserToGroup(group, user.getDirectoryUser())
Like Datta likes this
Georgiev-san
Thank you very much.
It was able to be settled!!
Best Regards, Takashi
June 9, 2016
Would you please mark the answer as accepted ? Thanks
it-service-frankfurt November 27, 2016
Hi Boris,
would it be possible to extend this script to create multiple new users, each one with multiple group memberships?
I am looking to replace an older Jelly script which will probably not work from JIRA 7 upwards.
Thanks in advance
Detlev
Michael Aglas
deprecated
Takashi Hattori June 12, 2016
Georgiev-san
I am sorry for the delay in my reply.
Yes,Thank you very much. I was able to handle it.
Best Regards,
Takashi
