How to use the first value of a cascading select in value field condition?
Nino Kienberg April 10, 2015
Hey there,
i have the following problem with JIRA Suite Utilities' Value Field Condition. I want to compare the parent value of a cascading select with an option_id, but i seem to fail with that. This seems to be a problem just with Parent Values, since a succeed with ChildValues. Is it just pure luck of mine that it works with the Child Values or is the way to compare Parent Values another?
Any hint is appreciated.
With kind regards
Nino
Paresh Gandhi
May 6, 2015
Just found workaround -
If you are looking to add condition in the workflow then add it as
Add condition > Script condition
e.g.
Script workflow function : Simple scripted condition : Checks script:
cfValues['field name']?.values()*.value[0].contains("value")
Pareshkumar Gandhi May 6, 2015
did you find any solution. I'm also facing same issue?
Register today
