How to use user select field in my forms?
Yanduganov Andrey
Hi!
I need to select users and groups in form in my plugin. I can use user picker and get username from it (or groupname for group) but how to use autocomplete? I have tried some ways but nothing works.
I need help.
Thanks.
Nic Brough -Adaptavist-
August 10, 2017
How are you drawing the fields into your add-on, and what type of add-on is it?
Yanduganov Andrey
August 10, 2017 edited
I'm not drawing fields. I just added input into velocity template. Then I added link like this:
"<jira>/plugins/secure/popups/UserPickerBrowser.jspa"
What do you mean?
August 11, 2017
The type of plugin was to ask whether it's a Server or Connect add-on, as they're structured very differently.
As you're working with velocity, that strongly suggests it's an add-on for Server.
Your attempt to include the field like that is simply not going to work.  A jspa page is a generated page that is built on-the-fly within a specific context.  You are demanding a rendering of it with no context sit, so there's no way it's going to work.
Your vm needs to implement the code in the field in context in order to do this.
Yanduganov Andrey
So, there is only one solution: to inmlement my own autocomplete? And is it really there is no way to use built-in custom field?
August 14, 2017
I suspect you might be able to parse the .vm file for the User Picker as it's built into JIRA, but you'll have to do it with the right context set, providing all the variables it needs in it.
Might be easier to use it as a base for your own coding.
Yanduganov Andrey
Thank you. However it is not solution that I wanted...
Help us plant more trees
