How to use velocity templates?
Yanduganov Andrey
Hi.
I found many questions and answers about velocity templates in Confluence. And what about JIRA?
I have tried example from this page:
// Create the Velocity Context
Map context = MacroUtils.defaultVelocityContext();
context.put("myCustomVar", customVar);
context.put("otherCustomVar", otherCustomVar);
// Render the Template
String result = VelocityUtils.getRenderedTemplate("/com/myplugin/templates/macro.vm", context);
 but I cannot find appropriate packages for MacroUtils and VelocityUtils in JIRA.
What packages I need to user for it? Or does exists anything else way to use velocity templates in JIRA?
Thanks.
3 votes
Yanduganov Andrey
To use Velocity Template you need:
  1. add Scanned annotation to your class
  2. add TemplateRenderer field with ComponentImport annotation
  3. add TemplateRenderer to constructor
  4. use it
For example:
@Scanned
public class MyClass {
@ComponentImport
private final TemplateRenderer templateRenderer;
public MyClass(TemplateRenderer templateRenderer) {
this.templateRenderer = templateRenderer;
 After that you can use it, for example
@Override
protected void doGet(HttpServletRequest req, HttpServletResponse resp) throws ServletException, IOException {
Map<String, Object> context = Maps.newHashMap();
resp.setContentType("text/html;charset=utf-8");
context.put("key", "value");
templateRenderer.render("path_to_vm_template", context, resp.getWriter());
somethingblue
July 26, 2017
Hi Yanduganov,
You'll want to use the JIRA templates and JSP's guide for Velocity Templates in JIRA.  MacroUtils and VelocityUtils appear to be for Confluence per the Confluence Velocity template documentation and I was unable to find references to those methods in the JIRA docs.
Branden
Gaston Valente
July 26, 2017
great doc, saves a lot of time, thanks!
Yanduganov Andrey
Hi Branden.
Your answer isn't about templates which I meant.
I write JIRA plugin and I have servlet. And I wanna render it using velocity template. I tryed write HTML just in java but I think that it's a wrong way.
