I have written a post function script to check the value of a multi-select list and when I check the field value, I see the option I want but when I attempt to use the contains() or any.equals() methods to validate this in an if/else statement, I am getting a false even when the value should throw a true.
Please find my script below:
import java.util.ArrayList
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
IssueManager issueManger = ComponentAccessor.getIssueManager()
MutableIssue curEpicIssue = issue
CustomFieldManager cfManager = ComponentAccessor.getCustomFieldManager()
CustomField productLineField = cfManager.getCustomFieldObject('customfield_17003')
ArrayList<String> productLineFieldValue = curEpicIssue.getCustomFieldValue(productLineField) //Multi select list field
log.warn("Current Issue " + curEpicIssue)
log.warn("Current Issue's issue type " + curEpicIssue.getIssueType().getName())
log.warn("Value from the Product Line Field " + productLineFieldValue)
log.warn("Class of the Product Line Field " + productLineFieldValue.getClass())
log.warn("Size of the Product Line Field " + productLineFieldValue.size())
log.warn("Does the Product Line field contain the value Others? " + productLineFieldValue.contains("Others")) //any().toString().equals("Others"))
log.warn("Does the Product Line field contain the value identity? " + productLineFieldValue.contains("Identity"))
if(productLineFieldValue){
productLineFieldValue.each {
log.warn("The following values are contained in the Product Line field's array: $it.value")
and the result returned is below
2024-05-14 10:29:04,367 WARN [runner.ScriptBindingsManager]: Current Issue OPM-15035
2024-05-14 10:29:04,367 WARN [runner.ScriptBindingsManager]: Current Issue's issue type: Epic
2024-05-14 10:29:04,367 WARN [runner.ScriptBindingsManager]: Value from the Product Line Field: [Others]
2024-05-14 10:29:04,367 WARN [runner.ScriptBindingsManager]: Class of the Product Line Field: class java.util.ArrayList
2024-05-14 10:29:04,367 WARN [runner.ScriptBindingsManager]: Size of the Product Line Field: 1
2024-05-14 10:29:04,368 WARN [runner.ScriptBindingsManager]: Does the Product Line field contain the value Others? false
2024-05-14 10:29:04,368 WARN [runner.ScriptBindingsManager]: Does the Product Line field contain the value identity? false
2024-05-14 10:29:04,369 WARN [runner.ScriptBindingsManager]: The following values are contained in the Product Line field's array: Others
From what I see, it contains my expected value but I still get a false when checking if it contains the value others.
For your requirement, I suggest changing your approach and use ScriptRunner's HAPI feature to simplify your code.
So in your case, if you intend to perform a validation on the values selected, you can try something like:
def multiSelectValue = issue.getCustomFieldValue('Multi-Select') as String //change the field name
if (multiSelectValue.contains('Value1') || multiSelectValue.contains('Value2') || multiSelectValue.contains('Value3') ) { //change the values
multiSelectValue.each {
Please note that the sample working code above is not 100% exact to your environment. Hence you will need to make the required modifications.
I hope this helps to solve your issue. :-)
Thank you and Kind regards,
Ram
This part is incorrect:
It's not a list of String values, it's a list of LazyLoadedOption (https://docs.atlassian.com/software/jira/docs/api/9.4.18/com/atlassian/jira/issue/customfields/option/LazyLoadedOption.html)
It shows values in log because of it's toString method:
public String toString() {
return this.getValue();
Try switching this:
To:
log.warn("Does the Product Line field contain the value Others? " + productLineFieldValue.stream().anyMatch(v -> v.getValue().equals("Others")))
Groovy-wise you could convert the lazyloadedoptions to string using for example
List<String> actualStringValues = curEpicIssue.getCustomFieldValue(productLineField)*.getValue()
Keep in mind though that Issue#getCustomFieldValue() can return null - so to avoid NPE's I'd recommend something similar to:
List<LazyLoadedOption> productLineFieldValue = (List<LazyLoadedOption>) curEpicIssue.getCustomFieldValue(productLineField)
List<String> productLineFieldStringValues = productLineFieldValue != null ? productLineFieldValue.stream().map(v -> v.getValue()).collect(Collectors.toList()) : Collections.emptyList()
Thanks a lot @Radek Dostál .
I will give this a shot. I had assumed that the options would be strings which now thinking of it makes no sense.
I will make the necessary adjustments and keep you updated.
@Ram Kumar Aravindakshan _Adaptavist_, I am not fully used to Hapi hence I went with the classic groovy/java approach which I am more conversant with.
I will have a look at your suggestion.
Thanks again.
Thanks a lot both of you.
I went with @Ram Kumar Aravindakshan _Adaptavist_ solution as it was the faster fix for the issue.
Thanks again both of you.
