How to view all the labels in a JIRA project
sumod pawgi October 10, 2014
I want to view all the labels I have created for a JIRA project. How can I view them? Some answers mention that I can see them in projects view. But my projects view does not show labels option on the left hand side.
Any other options?
3 votes
Akeles
February 6, 2015
According to https://answers.atlassian.com/questions/253966,
Atlassian have removed the labels project panel from Jira 6.2
Geert Graat
October 13, 2014
You should indeed be able to see all the labels in your project in your Project Overview on the left. The system add-on responsible for that is the Project Panels Plugin, which has a module Labels Panel. Maybe this module is disabled? BTW: assuming you have a current version of JIRA.
Another way to go is to use the Labels Gadget.
Geert
Maksim_Feshchanka
For Jira Cloud, could be used the "Labels Gadget" on a Dashboard.
It'll list all the labels in the particular project, and you could easily identify all the tickets and update the labels (merge/change/etc.) thru the Bulk change aption.
Nar Kumar C. - Narva Software
Hi Sumod,
Jira does not have this feature by default. However, you can use our add-on:
Advanced Label Manager for Jira
You can view all labels in a single place. It also has other label management features like searching, filtering, renaming and deleting.
Give it a try and let us know if you face any issue.
